what a piece of junk ! ! I keep breaking the steering cables , I figured out you can not use it as a zero turn you cant put any force on the steering the cables IT WILL BREAK ! Also the throttle cable broke , the choke cables broke , the front wheel bearings came apart , I had to buy a hole new wheel tire set up , it has a hard time turning tractor wants to go straight it been adjusted many times still does it . bottom steering shaft universal joint going bad ,parking break won't hole its been adjusted many times , charging system wire keeps coming apart
