Help
Pdivens
Cubcadet zero turn. Won t start. Cadet M48-HN (53AB5E6V150) - Cub Cadet Commercial Tank Zero-Turn Mower, 20 HP Honda (2003)?
Mower with GXV620K1 Honda engine will not start. It s been in the shop for 3 weeks without success. Brand new coils spark plugs and battery. Starter motor spins when bypassed doesn t engage when selnoid bypassed. Took out had tested told both were good.
Fly wheel Spins slow when trying to start then click due to battery drain and won t turn. Not getting spark I think because spinning too slowly. New Service tech thinks it s the starter (I don t) you can spin flywheel by hand so that s not the problem either. Doesn t spin while but for a few turn while plugs are out as well. We are both lost. Need help! All cables and electrical cleaned (ground positive safety switches) and checked.
