There called drive wheel release valves. they are generally located behind the seat and down in the engine compartment on a ztr. you'll generally pull them out and lock them in place releasing the drives so you can move the unit. If there separate pumps and wheel motors than can be on the pump itself and you'll need a wrench to crack the valve open.
