burrpenick
Its a bit corroded. I'm in the process now of TRYING to clean the main jet and tube, plus the other known passages like the fuel inlet, under the emulsion tube, and thru the needle seat. My first attempt didnt help- it still dies out after running 20-40 seconds. I'm soaking it more this time, and will check the jet and tube closer- although they both seemed OK the first time. Is there some tiny holes in the carb body/throat on the throttle side? I can seem something, but not clearly.
FINALLY, my question: Since this bowl is a little rough on the bottom, is it OK for me to try and polish is with some scotch brite etc?
thanks, George in NC ([email protected])
