jallen2845
- Jul 12, 2015
- 1
- 7
Hi all, I really need some help. I bought a really clean cub cadet gt1554 with a Kohler Command 27hp engine in it. The engine had 2 broken rods. I disassembled the engine and rebuilt it. 200 hours according to the mower. Found 2 broken connecting rods as suspected. Case was fine, pistons fine, rings within spec. I bought the parts and put it back together. I replaced the 2 rods, and the crank. New head gaskets, case (oil pan) gasket and put it back in the mower. It would not start and I suspected the carb needed cleaning, no idea how long it sat before I bought it. Anyway, it has very little (if any) compression. I can keep my finger on the plug hole while cranking it. I checked compression with a gauge and sometimes it goes to about 60 and sometimes its like 10-20. I can't figure it out! I pulled the valve covers and one of the rods was bent, it obviously wasn't bent when I put it back together. Valves looked good, and I verified movement of the rocker arms and valves opening and closing by turning engine over by hand. I pulled off all 4 rocker arms and took out the push rods and I still have no compression. Should I not have compression without the push rods in? Does that not eliminate valve or lifter issues? This engine has hydraulic lifters so no valve adjustment. Could the lifters be bad from sitting and that be what caused the bent push rod? But then shouldn't I have compression with the rods removed? Also, not sure how to describe this, but on the bottom of each head, under the valve cover, there is a hole, and compression comes out that hole when turning the engine over with the valve covers off. What the heck is that? I'm not an expert but this has me stumped. I used the book to reassemble. Do these engines have some type of compression bleed off or compression release? I just can't figure this out! Thanks in advance!
