HELP !!!! Scag Turf Tiger hydraulic pump or wheel motor issue?
scagy
  • / HELP !!!! Scag Turf Tiger hydraulic pump or wheel motor issue?
I have a 2002 Turf tiger with a 27 hp kawasaki model SST72A-27KA, serial #7750414. I believe pumps and wheel motors are original. The steering works fine when going forward, both left and right have equal travel and power. When going into reverse the right steering lever must be full aft in order to get any reverse control, and then it is not very strong. I would like to know if their is an adjustment that can be made to correct the situation? If no adjustment, what component should I look at first as the primary cause of this problem? Is their a systematic way to trouble shoot this problem?
Thanks
