HELP! Repair: Cub Cadet 6284 Radiator
m815
hi all,
i have a cub cadet 6284 that needs quite some tlc. anyway, the radiator fan blade has suffered dry rot and the blades have broke apart. the rest of the assembly works fine however. is it possible to just order the fan blade from somewhere? when contacting local cub cadet repair shops or cub cadet directly, they both only show the entire assembly and its $200+. any help would be great!
mike
m815
dougand3
I'd get the dimensions of your current one....like mounting bolts, diameter, etc. Then look online for a suitable fit. ebay, amazon, wherever.
