Help removing the electric drive clutch for my Ferris 5901079
scarcelle
I have already removed all of the fan belts to the mower deck and the hydrolic drive and now I'm having a problem removing the electric drive clutch from the drive shaft. Does anyone have any advice? Thank you.
I'm not familiar with these models. Can you get a puller on it? Wedge a screwdriver on opposite sides to apply offwards pressure on clutch, screw a bolt into the shaft, hit the head of the bolt with a hammer and the clutch might pop loose. gregjo1948
