Could be a number of things....
Obviously check your fuses and electrical connections first.
Is the solenoid actually clicking (working) ? If not, we will address that in another reply post.
If solenoid is working, then check power is getting to the starter motor? If it is and its not turning over, you have most likely burnt the starter motor out due to the stuck solenoid....
