rca1pollock
- Oct 24, 2019
- 1
- 1
I seriously need help. I rebuilt my JD 111 peerless 801 transaxle and believe everything was back together correctly. just put tractor back together and it will not move and will easily shift into all slots, but requires clutch depress to go into reverse. the motor shaft, belt and transaxle pulley are turning at same speed and direction no matter what gear, 1-5, neutral, or reverse, but tractor wont move. is it possible that the shift fork inside isnt around the shift collar anymore? or what? going to start tearing tractor and transaxle apart and see, but manual says it is thee "linkage not transaxle...do not remove!. the clutch does nothing but unload the tensioner so it isn't that?
