Hello all!
I've been searching and searching, but no luck! I have an old Yazoo self-propelled 24" cut mower, which I believe is a model S24. It has a Tecumseh HS-50 engine on it.
I recently rebuilt the engine (it threw a rod), and I had difficulty with the clutch cover with the double pulley going back on. There was a sleeve inside the pulley that goes over the clutch. The crank shaft would not fit through it, so I tried to hammer it in and that sleeve broke. Now, the pulley just lays loosely on the clutch is not usable anymore.
I thought about putting a straight double pulley on it, but I like to be able to disengage the blades by powering down the motor.
Does anyone have ANY idea where I can find a replacement clutch / pulley?? Please see the attached photos.
Thank you!
Thank you!
