- Sep 24, 2017
- 266
- 6,632
might be a long shot but There's a guy over on a utv forum i'm on trying to find the engine model number for a 2021 Mule SX FI it's a 401 CC engine (most likely a FJ400-____) but its a new EFI engine. He doesn't own the Mule, not sure why he wants the engine number
here's his exact question
What is the Kawasaki engine model number for the side by sides listed below. I had an older Ute with the 401cc Kawasaki FJ 400D, but it had a carburetor, and a flywheel magneto ignition system.
This new 401cc engine with EFI, and electronic ignition looks like a big improvement over the old. But, I can’t find the Kawasaki engine model number?
Kawasaki 401 cc (24.47 cu. in.) single cylinder, 4-stroke, gas
Bore x Stroke: 3.23x2.99 in
Compression Ratio: 8.6:1
Maximum Torque: 21.4 lb-ft @ 2400 rpm
Valve Train: Single-Cylinder OHV
Engine Vibration: Internal Counter Rotating Balance Shaft
Fuel System: Closed-loop electronic fuel injection
Horsepower (KW): 13.5 hp
Electrical System: Starter/Generator — Solid State Regulator
(Note: Some versions/listings state: "Alternator Output (max)22.9 amp")
Lubrication: Pressurized Oil System
Oil Filter: Spin-On (Item#: 49065-7010)
Cooling System: Air Cooled
Ignition System: Electronic Inductive Spark
Air Cleaner: Replaceable Dry Cartridge (item #: 11013-7029)
