For a little background, recently bought a house with a smaller fenced in backyard, maybe 0.25 acres in the Cincinnati, Ohio area.   It is pretty heavily tree covered, about 14 tall trees in that small area.  The front side of the backyardyard has decent grass growing, its kind of thin but atleast there is grass growing.  The backhalf, under the trees and just in front of them, have basically no grass.  I'm not sure if this is due to the previous owners not trying to get anything to grow there, or if there is just simply no way to get the job done.  Around there trees there are some shallow roots that I can see, and the area gets minimal sunlight, maybe 2-3 hours a day on a very bright day.
I've thought about aerating my entire yard and over seeding some sun/shade mix. I know it's hard for you to give good direction without seeing the areas I'm talking about, but hopefully you can atleast provide some direction on getting some hard to grow shady areas to get green and full. (My front yard is thin grass as well, so I'm hoping to bulk it up as well). I just know that if I'm going to do this I need to do it soon to get some growth before the first frost in October. Thank you for any help or feedback you can provide
