hi, i am looking for high lift or bagger blade for my mid 90's simplicity broadmoor with a 44" deck.
i have thick heavy grass and my mower will plug or bunch up with the stock blades.
i found a set of craftsman blades for a 44" zero turn mower that worked great, p# 7133144, (they are wore out now), two of the blades are standard and one high lift at the exit and that really blows the grass out. there has to be some place other than sears that i can get high lift blades. stock size is 16-1/8, with 3/4 hole. i have been looking but had little luck.
thanks
thanks
