Help identifying mystery B&S
DeltaT
Hi, I need to replace the engine on my old Victa tiller but the serial numbers are long gone. Can anyone recognise what I have?
Thanks in advance.
With a wet green scrubbing pad gently scrub the top of the shroud where the spark plug comes out. Should find numbers there. If not there scrub the side of the shroud.
DeltaT
Found it Rivets may thanks. Almost rusted away but the scourer revealed just enough to get most of the numbers.
