Engine help identifying engine
Little update. Got the coil out and the part numbers were worn off that too :) I called the place I bought the mower from (it is a few states away) and they used the serial to contact Exmark and get me the specific motor that came on it. It is rocking a FH580V AS-29.
-c
You can use this one. I have the same mower and mine is missing the tag as well, but I took this photo off another mower just like it.
How is your mower doing anyway? I have the same mower and a lot of experience working on it if you need help
