tiresharkdbb
- Oct 30, 2014
- 9
- 24
Bought mower used, and have been fixing it up. Float/needle is leaking... i can hold it upside down and still suck air through the gas inlet when it is supposed to be closed. I am trying to find a rebuild kit that will work... new needle and maybe seat i guess, if a new needle doesn't fix it.
FYI - I'm not 100% sure that this is the original carb, but it was working fine on the mower for 3 or 4 hours of use, until it started leaking bad.
Here is the info i have:
The carb itself is Walbro LMK and it has these numbers stamped on the side: 126 3075 2005316 Mexico. Underneath the float are the numbers 5-4704. There is no fuel solenoid on it.
The mower model number it is on is a 2006 LT1040 13AX10CG710 (Courage engine).
The reason i say i'm not 100% sure it's the original carb is because when i look up this Cub Cadet model number on parts websites, they list a carb with a fuel solenoid... part number KH-20-853-33-S (replaces KH-20-853-16-S).
Thanks for any help on this!!
