Hi, new here! I'm really sorry about this but hope you guys can still help me out.
I know this isn't a mower. I have a DEK ( Chinese Brand) chipper shredder. It's a 15 hp. After breaking it in with 10w-30 oil I changed the oil at about 6 hours. It was running fantastic. I changed the oil, with the same 10w-30, filled it up to the right amount and then put it back outside under the tarp. I didn't start it up, I should have but I knew I was going to use it in a few days. So about 4 days later I took the cover off and tried to crank it over. It was seized up. opened up the oil cap and BOOM. Water- oil came gushing out. So I know it was hydro locked. I'm really confused, I changed the oil, put the machine under the cover, and somehow a gallon of water comes pouring out. An advice is great guys, thanks.
