Hi all! Glad I found this place. Maybe I can get some help from someone here instead of the company that sells the stupid thing.
It's an 18 horse (Briggs) Craftsman GT6000 with 44" deck. Model number 917.255920.
My landlord was gracious enough to allow me to use the mower that has been stored at our rental for years. He told me all it needed was a battery... Yeah...
Put in a new battery and starter. Fired right up. Went to put it in gear, nothing.
Check the belts, the drive belt popped off. Belt is brand new.
Reroute belt... doesn't fit. Yes, the routing is correct.
No way to adjust tensioner pulley (as per Sears and their less than handy 'managemylife' people[because we all need a 7 dollar an hour hack sitting at a computer helping us manage our life]).
So, I have the correct belt length, according to Sears. 95"x1/2". When installed, the clutch petal is all the way down, but is so tight that the trans would be engaged. I went and got a 96"x1/2" belt. It's an inch too big, though the clutch engages/disengages properly, the belt is sloppy and just slips.
Riddle me this... How can the proper belt be 2-3 inches too small, but a belt one inch bigger be about an inch too big?
The routing of the belt goes around the engine and trans pulley, and on the outside of the clutch pulley, and inside of the idler pulley.
Any help is appreciated, and thanks in advance.
