Hello from Toledo Ohio
shagster042
How to adjust the ground speed on a Cub Cadet yard bug
Scrubcadet10
Moderator
Staff member
Welcome!!
When was the last time you replaced the drive belt?
Mower King
Welcome to the forum...Those mowers, as with most, have several linkages, pulleys and belts....check these parts to make sure they are working correctly.
HarmonySeeker
Welcome from a fellow Buckeye!
Do check the Cub Cadet section and good luck!
