Hello Forum
foehnerk
Hi,
New to the forum...joined to check out front end problems with my Sears/Husqvana tight steering 26 HP riding mower. No bent parts, can't figure out why the bearings on the right wheel keep wearing out. Have worn out two sets of bearings, the mower is only 4 years old. Never had these types of problems with my old standard turn circle riding mowers. There is definitely a lot of play in the front end. I have ordered some new cross links to see if I can reduce the play. Stand by.
k
mechanic mark
Post model & serial numbers from mower data plate as well as all numbers from engine data plate , thanks.
