I really need some help with my 1999 GT5000 tractor. I'm prying that some is able to point me in the right direction. It's going on 4 week now trying to figure out the issue with this tractor. Here are couple of my symptom 1) The brakes do not hold. Took brakes pads off clean up. 2) The transmission is stuck in neutral. Even with the brake pedal pressed all the way down. Note: lock in place. the wheel will still turn.
Note: I did check the fluid for the transmission for the level, and replace with 20-50 new fluid. At the moment that is the biggest issue.
Thank you so much in advance
