Height settings on a ZD326
jekjr
Have any of you had a problem with the height adjustment getting to where it is not calibrated?
It appears that mine is getting increasingly worse. I have not taken time to set it on a cement slab and measure the blade distance from the ground but it appears to be getting lower and lower as time goes by.
