heating problem
Keith Morgan
My neighbor owns a grasshopper model 721 and it runs very hot for some reason. He has cleaned the radiator at the car wash and checked the coolant level, but it still runs hot. Is there anything else that we should be checking that might cause the heat problem?
Keith
Thermostat not opening properly, or water pump impeller loose on shaft.
