The side that has lower comp is the culprit. The gasket is just starting to fail.
Pull the head and change it. Clean well and put it on there. You answered your own question when you wrote this.
Those gaskets are notorious for going bad all the time. When you take it off you see a small bad spot on the block side of it where the skinny part of the block is ~!~!
