Export thread
Hayter Harrier 41 starting problem....advice needed please
#1
D
dazzyst
Hi All,
Tried to start my Hayter Harrier 41 this morning to give my lawn its first cut of the season but she simply won't start. I replaced the spark plug thinking it may be that. There's plenty of fuel, oil is fine and no obstructions anywhere. I also checked the air filter and that wasn't too bad.
The only thing I noticed when I put her away last year is that when she started she did 'hunt' for a few minutes whilst the engine was warming up.
Any help would be appreciated.
Cheers
Daz
#2
pugaltitude
pugaltitude
More than likely the carb and fuel system will require to be cleaned.
Then add fresh fuel.
What model Briggs engine?
#3
D
dazzyst
How do I do that? Not sure the model of B&S engine I'm afraid.
#4
D
dazzyst
It's a model 12F802-1325-01. Hope that helps!
#5
pugaltitude
pugaltitude
I would think about taking it to a B&S dealer.
It could be fuel related which would mean removing the carb and fuel tank and giving a clean.
It could also be the ready start system that has failed.
The thermostat could be siezed which is not allowing the choke to go on.
It could also be a lack of spark from the spark plug surpressor cap.
You tube is a good place to find info as trying to explain is difficult.
