Hayter 485T Location of rear roller springs
Hayter
Had to remove the rear roller springs to push roller back to get to the cable post underneath the top of the body when replacing the bbc clutch cable. Don't think I have replaced the springs in the correct position. The cut height adjuster is quiet lumpy and when using the mower it doesn't seem to sit correctly on the ground. Can anyone steer me in the right direction of where they should be located. Thanks
