Having problems starting my 4619 Husqvarna zero turn, help please
bcraftman
  • / Having problems starting my 4619 Husqvarna zero turn, help please
Found, water in my carburator, fuel tank and fuel lines. I changed everything out along with a new fuel pump. had a very hard time crank the mower up. Finally started I let it run for about about 30 minutes before climb on the deck. as soon as I steped on the deck the engine stall out. It keeps on doing this what's causing this problem. Could it still be water in the carburator or a safety switch or something else ? Bruce.
Catherine
LawnWorld Support
Staff member
Welcome to the forum. I'm sorry to hear about your troubles.
I am moving your thread over the Husqvarna section. If anyone has the answer, they will be there!
KrashnKraka
Are you touching/grabbing the control lever as you step on the deck?
If so, step on free of mower. Try it.
KK
gainestruk
Yes you might still have water in bowl of carb, if it has anti backfire shut off unplug power and take out, gas will drain out, you can shoot some carb cleaner in hole to help dry it out.
If this doesn't work you will need to take carburetor off and take it apart and clean it.
And are you 100% sure you got all water out of tank ?
