I'm hoping to resurrect my Dad's early 80's Lawnboy push mowever. (Not sure of model, will update post when I can look for it. Looks like THIS though.)
It will not prime by pushing the button any less than an infinite amount of times.
I found if you pull the hose off the prime button and just blow in it until gas drips out of the air filter, it will then start no problem. I'm assuming its pulling the gas in through the air filter and starting at that point.
So now once it's started, it smokes a decent amount which I'm assuming is a result of running very rich. It works fine like this but I don't want to annoy my neighbors with the little blue cloud that will follow me around.
If I were to try repair myself (which I'm very interested in) any idea what parts are the culprits?
Should I get a quote to have it repaired or is it just past its time?
Thanks!
Thanks!
