Have a RZT50 Troy Bilt zero-turn mower w/ briggs & stratton engine.
cgoins502
  • / Have a RZT50 Troy Bilt zero-turn mower w/ briggs & stratton engine.
Need to check electrical fuse to see if it is blown. Where is it located? It shows shape of fuse in operator manual BUT
NOT where its located.
Most likely location is the the same area as the battery, and may be clipped to a body panel, or frame panel.
