hard to steer
Elpedro45
My simplicity Broadmoor is hard to steer. When front end is elevated it turns easily. Plenty of grease. Seems to get easier by the year.
Three areas which may cause your problem. Greasing front wheel axles where they go throng the front axle. Greasing the steering gear bearing/bushing on the end of the steering shaft, plus sector gear bushing. Improper tire pressure, should be 20 psi.
