Briggs & Stratton Model:
311707-0132-E1
Someone gave this mower to me about 2 years ago, and it's ran OK until recently. It's always been a bit hard to start, but always started. Now it won't start at all... when it turns, it hits the "hard" spot (I think this is the compression stroke?), stops, and won't do a 2nd turn. Doing research, I've found it's fairly normal for these engines to have compression release problems, and adjusting the valve clearance should fix it. I had never done this until searching this issue, and it didn't fix the problem. I just talked to the person who gave it to me, and he said in 10 years he had never adjusted the valve clearance even once. I'm assuming this can cause other problems?
Does anyone have any advice on what to do/check from here? I'd really like to fix it myself without having to put it in the shop.
311707-0132-E1
