Hard to start after 5 minutes
I purchased a used Husqvarna yth22v46 and just running it for 5 minutes it starts to drags to start,the starter barely turning over put jumper on it starts right up, Im taking the battery tomorrow to have checked just in case but when cold it starts right up, anything else could be causing this
One thing you can try, loosen up all the connections and re-tighten to clean off any corrosion that could cause voltage loss when hot. Does sound like a weak battery or charging system problem though.
