GX240 or GX270??
Scrubcadet10
Moderator
Staff member
Westinghouse water pump with a GX 2_ _
The recoil rope starter says GX240, the block says 270, BUT the model code i type in parts tree to look up parts, PA2 GCBJT, Only comes up as a GX240... GX270 apparently didnt use that designation.
I only need to order the 2 intake gaskets, and the the GX240's im pulling up look like exactly what i need so i guess ill send it and see...
I know the recoil could have been swapped, but for the parts websites to only pull up a GX240 and not a GX270 for those numbers seems odd.
