NewHolland GT20A
Hello people have a question for yall. For some time now I have had my charging light on and paid it very little attention till this year cause it wouldnt start. Tried to charge it manually with no luck so I replace the battery and began to test. No Voltage increase from static at the battery. Went to the stator got the 35ish VAC I should get. Next was the regulator got 10 amps dc out and 14ish volts dc. Mind you that I unplugged two connectors to test these two parts. Cleaned the connections and reassembled. That was the easy part. Im now getting a charge to the battery but the funny part is that the dang light is still on. Charging diagram shows no Light. Any guidance would be much appreciated!
