It has a Snap Ring you have to remove. Then use PBlaster or any other penetrating oil that is not WD40. Then a puller. The last hub I pulled required an 8-ton puller.
What does a 8 ton puller look like? I have these 3 prong jobs that have hooks on the end but I can't see how that would work. You also don't want to mushroom the end of the axle. IDK...
Also why not WD40? Just wondering
WD40 is not a penetrating oil. It is a water displacement product. WD= Water Displacement 40= 40ith try.
You better tell Wikipedia that one then "WD-40 is the trademark name of a penetrating oil and water-displacing spray. The spray is manufactured by the WD-40 Company based in San Diego, California."
IT is one of the 3 prong thing but really big.
I put a nut that will fit on the axel so it will get messed up instead of your axel.
You can also use this type of puller but they break easier.
