GS 6500 917.276910
phyrphighter
I am having a problem with the deck, falling off, I installed all new deck, lift arms, and such but noticed that it looks like it should have an anti-sway bar installed that is not there. I ordered the anti-sway bar, and I can see where the old one used to attach to the deck bracket. I have no idea where the other end goes. The manual says it goes to transaxles/transmission bracket. There is no such bracket on my tractor. Could someone show me a picture of where the far end of this anti-swaybar should go
Here is what you are looking for. Should be bolted to the left side of the frame in front of the tranny.
phyrphighter
Thank you. I don't have that although I can see where it would go. Wish I had the dimensions to make one because it does not seem easy to find.
