Groundsmaster 4500d Engine shuts down when barely releasing traction pedal...HELP!
Hvcceqm
I've already changed the fuel filter and made no difference. Not sure if it has something to do with the hydraulics or not...very puzzling.
Only seems to shut off when releasing traction pedal just slightly. Can run all day with traction pedal in full GO position. As soon as I let off just a little bit it's like someone reached over and turned the key off. Any ideas???
