grounding problem tractor 91725581
josefarina
Replace started solenoid. Engine started. Shut it off to move things. engine will not start again. Where to T/S. Ground?
As my pop would say. Look at the last thing you might think makes it no work. Just because you put something new it might have failed again. Mine did. First Thing Check Battery Voltage and voltage at solenoid. Put 12-volts to the switch side of the solenoid should kick off. If does Check your starter switch or button. I know this seems dumb but you never know. Hope this helps...
