how do i connect the ground wire from the key starter to the starter on an older john deere 180?
A ann137 Forum Newbie Joined Apr 9, 2013 Threads 1 Messages 1 Apr 9, 2013 / ground wire #1 how do i connect the ground wire from the key starter to the starter on an older john deere 180?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 59 Messages 15,307 Apr 9, 2013 / ground wire #2 The ground with on the key switch can be connected to any good clean surface on the frame or engine.
