Grinding noise and white smoke
julian_s
Hi I was using the lawnmower for the first time this season. I heard a somewhat of a grinding noise, like I was running over something, then white smoke started coming from the lawnmower. I didn't add any oil, checked the oil before I started, seemed okay level. There was gas from last year still in the tank that I used. If I start it now, there seems like less smoke but it will start smoking more after running and stalling a bit when idling. The machine is in its 5th season.
Any suggestions or diagnosis ? Thanks Julian.
Did you look under the deck to see if its all clear under there? Might have a cat or rodent nest up in there. Mice on top of the flywheel? Engine full of oil?
julian_s
Thanks for the reply. Engine was not full of oil. There was nothing underneath where the blades are, but I am not quite sure what constitutes the deck of the lawn mower.
julian_s
I drained the oil, put in new oil and made sure the level is accurate. I start the mower and it works fine for a few minutes and then starts blowing white smoke.
lefty2cox
What does it smell like and where is it coming from? The exhaust? Look for a sticker with a model / serial number and post it.
