Buying Advice Grinder?
Bomba
What do you use to sharpen the three blades on a 60" Exmark with a mulching kit??
I use a bench vice, and an angle grinder on all the blades I sharpen.
BWH
I use a Magna-Matic 9000 Sharpener along with a Magna-Matic 1000 Balancer. I put a better than factory edge on every time, it is really noticable is the health of the grass with a sharp blade.
mowerman05
I use a rotary blade grinder, (RBG) 10 inch 3/4 hp motor. works great but not cheap
motoman
10" H-Frt bench or pedestal grinder. You will grind freehand. Search thread tutorial this forum
Bomba
Thanks to you all for the advice. This place is sooooo helpful for stuff like this. I love how you all look after your equipment. I'm trying to educate myself on it so I can do the same thing.
motoman
Bomba, looks like a good start with your rig in the garage. Treat it like a good car and it will return the favor.
HarryHarley
I also use a Bradley Blade Grinder. For the price it works great for me.....
