Greetings
cia2a9
New to the forum and hope to feed off the knowledge and experience of others. Have a Troy Bilt Bronco, 42" 12 years old. Will be moving it to the garage for much needed maintenance.
Auto Doc's
Welcome to the forum.
For any machine you need help with be sure to provide the product label information for the machine along with the engine label information (Kohler), or the numbers stamped into the valve cover if it is a Briggs & Stratton engine.
Using the machine information, most parts can be located on Parts Tree or Jacks small engine.
