Great Dane chariot lx
Morodder
I have a Great Dane lx. when you let go of controls it does not return to neutral position automatically. what could be the problem? thanks alot
Jack17
Check both neutral return springs at the bottom of both drive handles. I don't think that they're broken...just in need of some lube...maybe? Also, check the damper/shock absorber at the end of the drive handles shaft making sure its got good resistance in its movement.
