For the life of me , I have tried every way possible to access the three grease fittings on pto shaft of my 725k, to no avail. Is it necessary to completely remove front deck in order to lube this area?? Thanks to all for any help.
I am new to my 725K2, but I have only found one grease zerk on the prop shaft and it is in the telescoping portion accessed by raising the floor board. Your model may be different.
Yes, I saw the pillow block grease fitting. I reached it from under the footrest platform. And yes, I am using an air assisted type grease gun. I am 75 yrs old and some of my arm strength has gone south, to make matters worse. They say to grease these fittings every 8 hrs of mowing time!!Ouch!! Oh well, back to drawing board.Now that I re read this, are you talking about the prop shaft with the universal joints or the pillow blocks on the straight shaft?
I pulled the rear universal joint loose on my 725K2 and there was the grease zerk for the front pillow block staring me in the face. I raised the foot rest, pulled on the lock collar to pull the prop shaft off and then an angled zerk was easily accessible.
Larry
