rsu11
- Mar 5, 2020
- 2
- 7
I have a 4 year old ZTX42 with a 22hp Kohler which will likely need a new battery soon. The battery in it now is small, essentially a motorcycle battery. It's much smaller than the battery tray will allow. Also, occasionally when turning the key, the starter will engage but not crank the engine. A second try usually gets it turning. The parts manual shows a 190cca battery, which seems a bit low to me. Has anyone put a larger battery in their Gravely/Ariens, and if so, which group size?
