Gravely zero turn the left control arm safety is giving me trouble.
millerboy
I push in the safety and it will start, then when the arms are pulled together, it stops. I do not know the model number as it is a friends unit.
Most common is if the brake switch failing or coming loose. Usually, the brake also has to be off when the levers are moved off their safety switches.
Another thing to check is if the system has diode in the safety circuit.
Lastly, check the seat switch operation and make sure the switch wiring is not rubbing anywhere and grounding out.
