Export thread
Gravely Model 915076
#1
M
mjharrell
I have a Gravely zero turn mower given to me and the 18hp courage motor has a crack, did research and found this is a common problem with kohler engines, is there a replacement for the SV540 series ? i am hoping the crack can be welded.
#2
D
Darryl G
There's been quite a bit of discussion of those engines here. I know one of the regulars discussed repairing them in detail but I couldn't find the post.
#3
M
mjharrell
i agree, these bucket engines are terrible, was hoping there was a briggs replacement
#4
Boudreaux In Eunice La.
There is a Briggs replacement ......... I did a repower not long ago for a guy with a Cub Cadet zero turn..... His Dis Courage engine cracked also.....
The cause of that is the bolts that hold the crankcover / sump get loose and the torque of the engine cracks the block..... I have a few friends that have that engine and they bring them to me 2 times a year to check the bolts and retorque.....
Last time I did it I put BLUE loctite on the bolts......
I'll look in my books if you are interested in the the model of the Briggs engine......
Let us know Mon Ami ~!~!
#5
Here's the result I got from my search...they don't seem like very good engines...
https://www.lawnmowerforum.com/search.php?searchid=7642899
Daryl that link is not popping up.........
#6
D
Darryl G
Ok, thanks. It works for me. I'll just delete it.
#7
M
mjharrell
Thank you, let me know what briggs replacement there is, i am going to see if the block can be welded, if it can be welded i will be using blue loctite on the bolts, would use red, but might need to take apart one day.
#8
I'll find it for you, keep in mind this was for a CC mower... Everything was a match as for as the wiring goes......
A few people on You Tube tried to weld with no success...... I even spoke to a welding specialist here in town on that and he said no go ........
#9
Ok.......... The one I repowered was the Briggs 33S877-0019-G1
I seen in my briggs power portal repower projects that a Ariens / Gravely 915087 was repowered with a Briggs 331877
I would need to know all info on your mower to confirm the engine you need.....
#10
M
mjharrell
let me know what ya need.
#11
Mower info ...... Model # and serial #
Engine info Kohler #'s on engine all the numbers....... Spec ETC ETC.........
How many pins on your plug harness also......
#12
M
mjharrell
Gravely ZT1840
Model 915076
Serial 020214
engine PS-SV540-0022
Engine Serial 3530915573
will get pin number tomorrow
#13
Gravely ZT1840
Model 915076
Serial 020214
Got it ..........
I'll let you know something tomorrow evening...........
#14
M
mjharrell
the connector for the engine is a six pin connector with only 4 being used.
#15
Ok .......... Got some info for you..... 33S877-0019-G1 is the engine that will fit on your mower....... Everything bolts up and plugs in.........
Plus Tard Mon Ami ~!~!
#16
M
mjharrell
Thank you, will let you know what the welder say's
#17
M
mjharrell
got the block welded up and in good shape and finally got it back together, now i have a problem with fuel spitting out the filter side with the filter housing and filter out and no power, figured that is flooding even tried a new carb with same result kinda stumped.
#18
M
mjharrell
found intake valve was not seating properly, lapped intake and exhaust valve back in and brought life to the engine even cut grass.
