well, there are plastic welding kits and a lot of how to's on youtube. Some industries weld the pipe together all the time and it holds against a lot of pressure. Also mower bone yards might have a good one. Without a model and serial, which tank, left or right etc., if multiple tanks, no one really is going to be able to give a definitive answer for your specific situation. I looked online and some of their tanks are only $150. Basically a steak meal for a family during the last three or four years. If you weld it, I might drill the ends of the crack, weld the crack with some filler rod, and then find a sheet to put over it and weld the edges to the tank. That should slow it for a few years. - unless it is a stress crack in a mount or something like that in which case it will fail again pretty quick.
