gravely compact pro chute flap/blocker & wider wheels
aussielawny
  • / gravely compact pro chute flap/blocker & wider wheels
Bought this mower the other week, bl00dy expensive here in Oz (over $9000) and first of all put 20x10-10 carlisle turf masters on it - had to do some grinding of the tank brackets to make it fit, but is much kinder on soggy lawns now...
then made up a chute blocker out of 5/8 steel, fabricated some brackets and welded them on...a couple of try outs showed a bolt needed to be added to hold it closed. Put on a gator g6 blade and it is mulching perfectly...
aussielawny
and a lawn done with it - cut at 1.5", this hasn't been blown - as it was after mowing
KrashnKraka
Sorry I carnt see yer pix to get an eye on what's been done.
My curiosty is raised tho' by whatever arrangement you have with the agent?
They are cool with mods being done?
.... back to you.
KK
aussielawny
try these
not sure what you mean re the agent?
KrashnKraka
try these
"this image has been deleted"... says the mighty (not) fotofarkit.com.
Buuut seeing as how you did give it a go I fired up
a PC and checked out your original post/s.
Gotta ask... you using low hydrogen rods? 2.5mm?
Whomever you bought the ride offn.
My experience has been mods - like tyre change (0D/HT) - has
them leaping all over the shop at warranty service times.
No?
I can see why you mulch, for mine it places unecessary load
on a ride plus no need to mulch here. Rains bucket loads most
days!
Cherrio...
KK
